Brake drum on 62 - NCRS Discussion Boards
Brake drum on 62
  • Terry D.
    • May 31, 1987
    • 2691
    Brake drum on 62
    Not at home so I need a little info, what is the standard inside diameter of a front and rear brake drum on a 61-62 Corvette? Also what is the point when you should replace due to wear?
    • 6942
    Re: Brake drum on 62
    Terry I believe its 11.09 inchs,
      • 15667
      Correct. Nominal OE diameter is 11.0". Later service drums had the 11.090" max diameter stamped or embedded in the casting. This was a new FMVSS that went into effect, IIRC, on Jan. 1, 1968, and it also applied to minimum disk rotor thickness.
      • Terry D.
        • May 31, 1987
        • 2691
        Thanks Duke
