#059 to #173 1959 Generator Change-over Date?? - NCRS Discussion Boards
  • Al R.
    • June 30, 1988
    • 687
    Does anyone have or know the approximate serial # that GM changed from the #059 generator on the 1959 290HP FI cars to the #173? I know my car serial #4388 has the #059. Just curious. Also, does anyone have detailed pictures of what the #173 generator looks like. I have one that has the tag on it for a 60 build date that I took off a 60 vette that I owned back in the early 90s (that would not charge), but the end plates look different than the #059 on my '59. The front plate of the #173 I have, is made of aluminum with a large rubber bushing with mounting hole at the front and a small hole in the rear plate about the same diameter as the #059 for mounting it to the bracket. I would just like to verify that the #173 is indeed a 173 or if it is something else that has the metal tag installed on it. The Delco tag has the following stamped into it 1102173 and 0B12 for the Feb 12, 1960 date which would have been correct for my old 60 290HP FI BB car which was built in March of 60, if I remember correctly. I think it had a serial # of 53??. Thanks for any help on the pictures and other info!! Al
  • Ian G.
    • September 3, 2007
    • 1114
    Re: #059 to #173 1959 Generator Change-over Date??
    I can't say for certain, but this is one on ebay currently and the end plug looks lie others I've seen searching around in the past.
    This is what the endplug for my personal 059 looks like:
    • Mike E.
      • February 28, 1975
      • 5134
      The ebay one cited sure looks like a repro tag and rivets. When that is the case, one has to be dubious about the originality of the rest of the piece.
      • Cecil L.
        • May 31, 1980
        • 449
        Sounds like you have a 174 with a 173 tag. the 173 was solid mounted on the front frame and the 174 had a rubber bushing mount on the front, otherwise they were the same. the 173 is visually like the 268 and used the same end plates but has some internal differences.
        • Cecil L.
          • May 31, 1980
          • 449
