1967 427 AC 390HP water Pump Pulley Part number suffix - NCRS Discussion Boards
  • Tim S.
    • March 1, 1989
    • 124
    Is a 3889372 BF three groove pulley the correct one for the 67 BB AC cars?
    Does it matter if it has the alpha code in it? Could it be just a 3889372 with no suffix?
    Thank you
    Tim
  • Peter M.
    • May 30, 2013
    • 358
    Re: 1967 427 AC 390HP water Pump Pullry Part number suffix
    Tim,
    Mine does not have the prefix code. It does have a "S" 180 degrees from the part number.
    Kind regards
    • Tim S.
      • March 1, 1989
      • 124
      Peter thank you for the info and picture. So would you think if the pulley had an alpha suffix is was incorrect?
      Regards
        • 43221
        Thank you
        Tim
        Tim------
        GM #3889372 is the correct waterpump pulley for your application. Most that I have seen do have the "BF" suffix code. However, personally, I would not consider one without the code to be incorrect.
        • Peter M.
          • May 30, 2013
          • 358
          Tim,
          You're welcome. I think either way is possible. My car has had work done to it in the past, so I can't say with certainty it has never been replaced.
          Kind regards
