C2 Unusual Rear End Date Stamp - NCRS Discussion Boards
  • Daniel B.
    • November 28, 2016
    • 13
    I am new to posting on the Forum. Thanks for all the great help and advice the forum offers. I discovered my '67 L71 apparently has an unusual rear end date stamp. The stamp reads AZ 7 C 10 (the casting shows K 4 6). The specs show the AZ decodes as a 1967 3:55 posi. No problem with this portion of the stamp. But according to the references, the date portion of the stamp should be all numeric and not contain any letters. Is the 7 C 10 an alternate stamp for March 10, 1967 on a replacement differential, or is there some other known explanation for this stamp? Or is it just a botched stamp by someone clueless? Photo is attached.
  • Timothy B.
    • April 30, 1983
    • 5202
    Re: C2 Unusual Rear End Date Stamp
    Daniel,
    Welcome the NCRS forum.
    I am thinking that rear is from a 1977 car. I believe that date format is typical of that Era and I think the AZ code was still used but not sure what ratio it denotes.
    Do some research in the archives if you have time and you may find the answer.
    • Paul D.
      • September 30, 1996
      • 491
      As per my trusty old GM Parts book, AZ was only used in 65, 66, 67, and 69 and only with Big Blocks. 3.55 ratio with posi H.D.. Chip.
        • 6958
        Dan the stamped numbers and letter are not typical, it appears to be a re-stamp,
