1970 350/350 with AC Heater Hose Routing - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 209
    I had a heater hose (that goes the the intake nipple) rub and break on the AC compressor pulley. The 2 heater hoses (upper/lower) were routed through the bracket which is connected to the AC compressor as per the AIM. Does anyone have a picture of the hoses going through the bracket on the AC compressor and or can you guide me to properly route/install? Thanks.
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
    • 6950
    Re: 1970 350/350 with AC Heater Hose Routing
    Will, If you have a AIM, it should have a diagram under option C60. In rear of AIM.
    • William H.
      • January 1, 2006
      • 209
      I used the AIM and the 2 hoses go through the bracket on the AC compressor. But, the upper (smaller) heater hose is rubbing on the AC pulley. I'm not sure how to avoid the rubbing? Thanks for any ideas or pictures.
      Bill Hyndman
