Duke suggested I post this because he's not sure what's going on.
Over the weekend, I tried to change my L36 4 speed TI distributor from ported vacuum to full manifold vacuum. I tee'd off the hose coming from the intake manifold to the vacuum canister for the headlights and the windshield wipers since I know for sure this is full vacuum.
However, after I made the change and started up the car, I expected the idle would have increased because the timing was now advanced by several degrees. But I got a surprise when the idle didn't change at all! I'm still running 700 RPM with full vacuum or ported vacuum, or even with the vacuum completely disconnected!
At first I suspected a bad vacuum canister, so I put my trusty Mityvac on there, but as you can see from THIS VIDEO (watch the brass flat head screw on the stationary pole piece and the gauge), it starts moving at around 7" Hg and is all in at around 13" Hg, so that's not the culprit. (Sorry for the crappy video, but it's hard to do this and work the vacuum pump at the same time!)
So does anyone have any idea why my idle is at 700 no matter what vacuum source (full, ported or none) I use?
Ed
Ed
