Engine Suffix Code Labels / Date Coded Seat Belt Labels - NCRS Discussion Boards
  • Guy B.
    • February 3, 2017
    • 32
    Looking for a reproduction engine suffix code label and date coded seat belt labels for a 1972 Corvette 350, are these reproduced? Can't seem to find either.
  • Dan A.
    • May 31, 1974
    • 1073
    Re: Engine Suffix Code Labels / Date Coded Seat Belt Labels
    Member Patrick Hulst may be able to help you with the engine suffix labels.
    • Darryl D.
      • February 7, 2017
      • 386
      What would these be used for?
      • Guy B.
        • February 3, 2017
        • 32
        It's in the NCRS Judging Guide, just had my car judged last week did real well but looking to finish off a few action items
          • 11698
          Engine identification as they run down the line. It's easier to check a large sticker than the tiny stamped code on the stamp pad.
          They are still used to this day.
          • Guy B.
            • February 3, 2017
            • 32
            Patrick, can you help me with this?
            • Jimmy P.
              • June 24, 2014
              • 1696
              Hi Guy,
              Here is an example of my 73 engine suffix code yellow label that Patrick made for me. Keep in mind your 72 will have different letters and numbers specific to your engine and options. He really does a great job and he's very reasonable. As far as the Seatbelt labels, I'm not sure if Patrick does those, but places like Snakeoyl may reproduce the tags. It's all about getting the correct tag material for those though. You could also check with Charlie Santorelli at Seatbelt Sity he may have tags for you.
              Hope this helps!
              Jimmy
              1973 Convertible
              L48,M20,N40
              Mille Miglia Red/Oxblood
              • Guy B.
                • February 3, 2017
                • 32
                Thanks Jimmy! Looks great
                • Dan L.
                  • May 9, 2012
                  • 97
                  I have added PS to my 66 L79 using all correct period correct components. The car dose not have AC does that change the engine suffix - currently HT. I can not fine any reference to a factory equiped PS non- AC car in the engine specs material. Thanks
                  Dan - 54915
