Spark plug diagnosis chart - NCRS Discussion Boards
  • Frank K.
    • January 1, 2000
    • 319
    What causes compression leakage ( Spark plug has burnt looking band close to were plug wire attaches)
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Spark plug diagnosis chart
    Do you mean this:
    • Frank K.
      • January 1, 2000
      • 319
      Exactly! The rear plug (No7) Thats were the intake manifold has a problem on vacumn leaking on the china wall. Common problem on Late C4. The oil in the air attaches to the plugs porcelan.
        • 15626
        On LT1/LT4 engines the EGR tube, that comes from the passenger side exhaust manifold to the EGR valve at the back of the intake manifold, heats the RTV on the rear china wall and deteriorates the RTV. The heat/cooling cycles also loosen the right rear intake manifold bolt. The combination of the deteriorated RTV and loose intake bolt results in oil/vacuum leaks at the #8 cylinder. The solution is re-gasket the intake and properly torque the intake fasteners.
        • Keith B.
          • September 15, 2014
          • 1596
          this seams like a problem that never can be fixed. a job that will be required forever.
            • 15626
            Just one of the many tasks that are routine maintenance for driven vehicles with GEN II LT1. I manage to do it, along with Optical distributor, spark plugs and wires and EGR about every 100K miles. Water pumps, serpentine belt & tensioner and oil cooler hoses more often, on an as needed basis.
            As someone once said: "If you are going to golf, you have to buy golf balls."
            I doubt there are too many C4s that hit those kinds of mileage numbers, but there are probably a few.
