I took my 66 to our chapter judging meet this weekend. I got either just a comment or comment and deduct (not sure which until I see the sheets) on my jack paint. The screw shaft on my jack is unpainted steel, the judge said the screw shaft should be painted black.
The 66 TIM&JG says "The jacking screw is natural steel with an off-white nylon washer sandwiched between two large zinc/cadmium plated steel flat washers under the 3/4" hex head..."
I also checked the 67 TIM&JG just to make sure there wasn't some confusion. The 67 guide says "The jacking screw is natural steel with an off-white nylon washer sandwiched between two large zinc/cadmium plated steel flat washers held in place by a 3/4 inch nut."
The pictures in both guides of the jacks sure look like the shafts are painted, and since the judge was a senior judge I have no reason to really doubt his comment.
SO, are both guides incorrect?
