69 427 Clutch Opinions - NCRS Discussion Boards
  • Brad H.
    • January 27, 2009
    • 250
    It's about time to change the clutch on my 69. There are so many on the market these days, I was hoping some of you might have recommendations for it. The car is stock and numbers matching but I'm not worried about the clutch being an OEM unit. Engine is a stock L-36 and I'm more interested in smooth operation than anything else. Thanks for any recommendations you may have!
    Brad
    • 15706
    Re: 69 427 Clutch Opinions
    Any auto parts store should be able to set you up with a LuK OE 11" replacement clutch. They will provide excellent service for normal road use, but may not be the best if you like to side-step the clutch at 5000 revs on a regular basis. Avoid "racing clutches" unless you are really racing.
    • Brad H.
      • January 27, 2009
      • 250
      Thanks Duke!
      I'll look into it.
      Brad
        • 43279
        Originally posted by Brad Hood (49930)
        Thanks Duke!
        I'll look into it.
        Brad
        Brad-------
        LUK or Sachs clutches are the closest thing to OEM that you can get other than NOS GM.
        • Brad H.
          • January 27, 2009
          • 250
          Thanks Joe!
