1963 Motor Mount Bolts - Grade 8? - NCRS Discussion Boards
  • Rob M.
    • April 17, 2014
    • 44
    Are the motor mount bolts for 1963 all suppose to be Grade 8? I am talking about: (i) the 6 bolts attaching the motor mounts to the engine block [ 3/8-16 x 7/8]; and (ii) the 2 bolts that attach the motor mounts to the frame [ 7/16-20 x 4]. I'm not sure if the bolts from my car are original and the frame bolts appear to be Grade 5 (three slash marks with "BS" initials). Thanks, Rob.
  • Jim L.
    • September 30, 1979
    • 1808
    Re: 1963 Motor Mount Bolts - Grade 8?
    Grade 5 is likely proper. There would be little point to screwing hardened grade 8 bolts into the soft (relatively speaking) iron block.
      • 43221
      Rob------
      The GM #3774078 bolts (motor mount to block) were GM-280M material grade (SAE grade 5; 3 radial lines).
      The GM #3817224 bolts (motor mount to frame bracket) were also GM-280M material grade. These bolts were 7/16-20 X 3-7/8" and were zinc plated. These bolts had a piloting, chamfered tip.
      By the way, in 1974 GM did go to GM 300M grade bolts (SAE grade 8) for the motor mount to block application on Corvettes. These bolts were GM #331246.
      • Rob M.
        • April 17, 2014
        • 44
        Thank you both for the help!
        • David L.
          • July 31, 1980
          • 3310
          A few months ago I sold a pair of 63-65 Corvette motor mount bolts that were 7/16"-20X 3 7/8" and marked "UR" with 3 radial line segments (grade 5). I have a few photos of them if anyone is interested.
          Dave
            • 43221
            Dave
            David------
            Are they zinc plated?
            • David L.
              • July 31, 1980
              • 3310
              Joe,
              I believe that the bolts were zinc plated. Lately I've been having trouble inserting photos to my imgur account. When my son visits us I'm sure he will figure things out.
              Dave
              • David L.
                • July 31, 1980
                • 3310
                Joe,
                Here are the photos.
                Dave
                  • 43221
                  Dave------
                  These are exactly as I would expect them to be (although, of course, manufacturer's headmark could vary).
