I've read several informative threads on deck height fluctuations, mostly relating to the small blocks from the Flint factory, but relatively little about the big blocks coming out of Tonawanda. The blueprint standard, nominal deck height for the small block is 9.025, and apparently it's not uncommon to find them as high as 9.040", but surely there must be shorter than 9.025 as well. By comparison, the nominal deck height for a big block is 9.8" (not including the 10.2" tall deck for truck applications), but I haven't read much about the specific highs and lows for the big blocks.
It seems reasonable to me that due to the reality of acceptable manufacturing tolerances in a mass production environment, some blocks were taller than the nominal spec, and some were shorter, and I imagine the same is true for rods and pistons, albeit to a lesser degree.
Question #1: In your experience, what's the highest and lowest deck height you've aware of for an original, unmolested big block? For a small block?
Question #2: Obviously, taller-than-spec blocks, while reducing the quench and CR, did not pose the risk of piston-to-valve collisions that shorter-than-spec blocks pose. So, did the factory automatically trash those shorter-than-spec blocks?
Or, did they just double up the standard gasket, or use a thicker gasket? I believe I saw a thread where somebody (Duke?) noted that Flint used double shim gaskets in the early '60s. Did they do the same in the later 60s, and with big blocks?
Or, and this is pure speculation on my part, were the short-than-spec blocks set aside to be paired up with taller-than-spec rods and pistons, in order to get the piston-to-valve spec back into the "comfort zone."
I'd love to hear your thoughts!
Sam
Sam
