70 LT-1 Carburetor Base Gasket - NCRS Discussion Boards
  • George C.
    • April 11, 2010
    • 44
    I have a 1970 LT-1 with a Holley 4150 (list 4555) carburetor and the stock Winters aluminum dual plane intake manifold.
    I have been told the open carburetor gasket will allow a small leak across the divided plenum with the opening it creates under the carb baseplate and this leak will weaken the strong intake signal that a dual plane produces and could have an impact on jetting and idle.
    What carburetor base gasket should I use; open or 4 hole?
    • 43248
    Re: 70 LT-1 Carburetor Base Gasket
    George------
    The original carb base gasket used for ALL LT-1's was an open plenum type. You MUST use this type. The LT-1 manifold carb flange will not support the 4 hole type gasket.
    • Christopher K.
      • September 10, 2007
      • 311
      George,
      This one is almost identical to the original which is impossible to find.
      Free Shipping - Holley Carburetor Base Plate Gaskets with qualifying orders of $109. Shop Carburetor Base Plate Gaskets at Summit Racing.
      May also solve any vacuum leaks
      Chris
      '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
      '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
        • 43248
        Originally posted by Christopher Krieger (47844)
        George,
        Chris------
        1970 LT-1 did not originally use a gasket like this. Non-EEC cars used only a thin, open plenum gasket. EEC used an aluminum shield with 2 attached thin gaskets.
        • Christopher K.
          • 311
          Thanks Joe for the correction. I forgot the '70 Lt-1 was configured differently. Interesting difference between EEC vs Non-EEC.
          Chris
