C2 Accelerator Pedal Rod support - NCRS Discussion Boards
  • Jeremy R.
    • May 23, 2012
    • 137
    Quick question for a C2. On the accelerator pedal rod support that bolts to the firewall/transmission tunnel and the pedal rod fits through, which way is it supposed to be oriented: longer end of the tube inside the driver's compartment or out? I believe it is supposed to be in, but my was bent up and probably been taken apart before so I want to make sure I am getting back in correctly.
  • Jim D.
    • 2885
    Re: C2 Accelerator Pedal Rod support
    Here's a pic. of my 65 during restoration. I hope it helps.
    • Wayne M.
      • March 1, 1980
      • 6414
      Here's another pic; longer tube on the interior.
      • Jeremy R.
        • May 23, 2012
        • 137
        Thanks all. I thought I had the right configuration, but I can never be sure with this car.
        • Leif A.
          • August 31, 1997
          • 3658
          Damn Wayne, did King Kong get ahold of that??
          Leif
          • Jim D.
            • 2885
            Remove the bolts? I don't NEED to remove no stinkin' bolts.
