thatreplacementQUESTION #1QUESTION #2: What am I missing here?? In other words, how did the CR increase, and how did the compression height increase?
Also, the stated weights for the piston and connecting rods are equally confounding to me. For example, the L-72 piston (GM#3888342) is listed at 25.46oz in 1966, while the seemingly identical L-71 piston (same part, GM#3888342) is listed at 24.67oz. in both 1967 and 1968 Vehicle Info Kits. The L-72 connecting rod is listed at 27.84oz, yet the seemingly identical rod for the L-71 is listed at 24.67oz in 1967 and then magically back to 27.84oz again in 1968!!
QUESTION #3: Are the pistons, connecting rods, and cranks for the L-72 actually different from the L-71 despite having the same GM part numbers and dimensions??
Finally, I've read many times that when plotting horsepower and torque curves, they necessarily cross on the graph at exactly 5252 RPMs.
QUESTION #4:Why do the dyno graphs in the Vehicle Info Kits show the curves crossing at what appears to be only 2,600 RPMs?
Thanks in advance!!
Sam
Thanks in advance!!
Sam
But, if your pistons are truly 36.3cc, and the block is .005" shorter than nominal (yes, they exist), and the combustion chambers are a mere 1cc smaller than spec (that happens too), you're at about 11.9:1, and probably no stranger in the land called "Deto-Nation."
