Hoping some of the fuel injection owners can help diagnose my stalling condition during hot idle on a 65 FI car. I am just getting familiar with the car and have adjusted the cold idle to 2200, but from there it gets harder to stabilize. Not sure the tach is accurate on lower rpm but my ear tells me I can adjust the hot idle to about 900 although the tach reads closer to 1300. If the tach is true, I cannot lower the hot idle under 1000 without stalling it. I even got the idle smoothed out so the needle stayed within 2 hash marks at best. Driving the car at that point was very smooth and responsive, no flat spots on acceleration. But when I come to a stop, and let the car hot idle, it becomes erratic after 1-2 minutes then stalls. I replaced the fuel pump and fuel filter, fresh non ethanol gas and octane boost.
Another unusual sign it it seems to take a little longer than it should to rev down. I have more experience with a 63 FI that will wind up and come back to idle quicker. This one tends to float down. I did a quick check on the throttle valve and it does not appear to be binding. Could these problems be related? Any help is greatly appreciated! Thanks, Dan
