C4 Timing chain front cover - NCRS Discussion Boards
  • Frank K.
    • January 1, 2000
    • 319
    On the driven gear shaft there is an o-ring seal! Does any one no the part number? Its for a Vin P Motor
    • 43246
    Re: C4 Timing chain front cover
    Frank------
    There are several seals on the front cover as follows:
    waterpump drive shaft seal (pressed into front cover)-------GM #10217886
    waterpump drive shaft seal (this is an o-ring type seal)-------GM #12553792
    distributor shaft seal (pressed into front cover)------GM #10128317
