1963 L84 Valve Cover Screw/Bolt - NCRS Discussion Boards
  • Lothar K.
    • April 30, 2000
    • 12
    Approximate 1963 Corvette production number for switch from phillips head valve cover screws to "M" hex head bolts on the L84 engine...???
    Thank you
  • John D.
    • December 1, 1979
    • 5507
    Re: 1963 L84 Valve Cover Screw/Bolt
    Lothar, I have been watching to see if you got any replies. My 9900 has Phillips and 19,000 I owned had hex bolts. I have thought that the change from phillips to bolts occurred in May but have seen original cars later than that with phillip screws. I see that the 6th edition says that late 63's had the hex head bolts.
    Took me a long time to find the correct phillip head screws. They are a driven screw which means the Plus sign on the screw is wider and deeper than a typical hardware store screw. The head on originals is also thicker. Now maybe someone will chirp in. Thanks, John D.
      • 6950
      To add to Johns post the JM spells out late as being the last 4 months. Maybe someone will post dates on there hex heads. my car is like Johns 10,6xx. I think you may find a approx. date only and that during Judging, It may be a no deduct anyway with most, or maybe 1 pt..
      • Lothar K.
        • April 30, 2000
        • 12
        My car is a late March build car....Thank you for the reply
          • 6950
          You should be safe with Phillips screws.
