What is the correct mounting for the 1967 Headlight Motor Switch? The Judging Guide states the ears are to be above the lower lip of the instrument cluster with the mounting screws flush with the lip. I have tried to mount the switch as outlined but cannot seem to get the tabs above the lip. Although the picture in the manual is not very clear it appears the ears are mounted below the lip with the screws flush with the ears. This is how I currently have it mounted and appears to be correct. I received a deduction for this and want to correct prior to the next meet.
C2 1967 Headlight Motor Switch
Re: C2 1967 Hewadlight Motor Switch
Behind/above the lower lip is correct. It is a bit of a PITA to accomplish but that is the correct way. If the cluster has ever been out of the car or if the switch has been replaced in the past, what you currently have is often seen as it is easier to do that way...just not correct. BTW, I found out the hard way, also, during my first round of judging.Leif
Top Flight 2017 Lone Star Regional- Top
If you look at the switch mounted below the cluster from the side and then mount it correctly it is easy to see the correct mounting looks better as the curve of the switch matches the cluster.
JR- Top
Re: C2 1967 Headlight Motor Switch
...Although the picture in the manual is not very clear it appears the ears are mounted below the lip with the screws flush with the ears. This is how I currently have it mounted and appears to be correct. I received a deduction for this and want to correct prior to the next meet.
Attached FilesLast edited by Nick C.; May 24, 2017, 01:45 PM.- Top
Harry and Joe,
My 67 without A/C is as Joe and Nick describe. My 67 with A/C is as you describe. Leif's car has air and it would seem he has been able to mount his above the cluster flange. I could not get mine to fit above the cluster because of the column bracing. Maybe I gave up too easy. I had another 67 A/C car years ago and it was the same. I believe both cars had the clusters removed at one time previously though. My 67 A.I.M. is not handy but I will see if it shows anything.
Kind regards- Top
Here's a picture of mine...Attached FilesLeif
The contour of the instrument bezel does not change because of the addition of AC. Now the bezel is cut out on the inside closest to the column when AC is added so the switch will fit. When AC is added the switch has to be moved because the left AC duct distribution is in the way of the switch.
If you put the switch with the tangs on the outside of the instrument bezel it does not fit correctly. Notice How Lief's switch fits correct as does the picture that Nick provided.
JR- Top
I believe this AIM page cancels the removal of the cluster tab removal needed for the inboard location on 67 A/C cars. Credit John HinckleyAttached Files- Top
Search the archives... I'm certain this issue has been beat to death a number of times.
Attached Files- Top
Here's a shot from the rear clearly showing the intended configuration with the switch housing tabs above the cluster flange and the 2 flatnuts.
I typically add a dab of 3M strip caulk(dum-dum) to the ends of each flatnut to help hold them in place to the tabs.
If the car is Radio equipped, there will be a Capacitor mounted on the backside for the Battery Gauge. You MUST move or remove this Capacitor to get at the inboard flatnut to hold it in place with a tool or your finger to get the screw started.
This shows how the profile of the switch mates to the cluster.
- Top
It's in the '67 AIM Brian. It's shown on a page with the word "cancelled" stamped across it but the cancellation is in regards to the vent cable knobs which were moved for '67. When I get home, I will post a pic for you. I don't know how you would be able to get the headlamp rollover switch to not interfere with the A/C ducting in the left hand (without A/C) location.Leif
