C4 antifreeze - NCRS Discussion Boards
C4 antifreeze
  • Frank K.
    • January 1, 2000
    • 319
    C4 antifreeze
    Is each year unique to its type of antifreeze? I see Dex Cool as a recommended product to my 1993 LT 1 engine?
  • Jim T.
    • March 1, 1993
    • 5351
    Re: C4 antifreeze
    I am still using the same Dex Cool in my 1996 LT4, been using it since it was new every 5 years.
    • Keith B.
      • September 15, 2014
      • 1588
      Re: C4 antifreeze
      95 or 96 was the first year for Dex Cool. Your 93 defiantly had green
      • Frank K.
        • January 1, 2000
        • 319
        Re: C4 antifreeze
        It is green&yellow zerex i guess!
        • Michael W.
          • April 1, 1997
          • 4290
          Re: C4 antifreeze
          Coolant colour is meaningless these days, no longer a sure indicator of type or compatibility.
          Go by the spec that GM states and make sure any top ups are also the correct spec.
            • 15706
            Re: C4 antifreeze
            I recall it was '96, except Saturn. For prior vehicles that used IAT "green", I recommend HOAT Zerex G-05. Duke
              • 43247
              Re: C4 antifreeze
              Frank------
              Here's the "long and short of it":
              Corvettes at least through 1994, if not 1995, require a coolant meeting GM spec 1825M. Prestone "yellow/green" and Zerex G-05, among other coolants meet GM spec 1825M. Dex-Cool does not meet GM spec 1825M.
              All 1984-96 Corvettes use a heater core which is copper/brass with solder joints. Zerex G-05 is slightly easier on copper/brass and solder than Prestone "yellow/green". You want to do everything possible to postpone the need to replace a C4 heater core for absolutely as long as possible. So, I use Zerex G-05.
              A tip for 1996 Corvette owners: The cooling system for 1996 LT1/LT4 is essentially the same as 1992-95 LT1, including a copper brass heater core. While I rarely deviate from GM recommendations, if I had a 1996 Corvette I would not use DexCool. I would use Zerex G-05. Plus, at this point, you don't need to be concerned about warranty requirements.
              • Frank K.
                • January 1, 2000
                • 319
                Re: C4 antifreeze
                Thanks That heater has never been on! but i did change my C3 core and it was a mess.
                  • 43247
                  Re: C4 antifreeze
                  Frank------
                  Replacing a C3 heater core is child's play compared to replacing a C4 heater core.
                  As far as the heater never having been on, that would have little effect on the longevity of the core. Corrosion proceeds inexorably.
                  • Frank K.
                    • January 1, 2000
                    • 319
                    Re: C4 antifreeze
                    What can i do to purge it?: Can i bypass it like i did on my 77? I see Ecklers has a item to bypass the constant heat going into the cabin for the 77.
