Vehicle weights - NCRS Discussion Boards
Vehicle weights
  • Mike E.
    • February 28, 1975
    • 5141
    Vehicle weights
    72 has the weight stamped on the blue certification label. Earlier cars have the shipping weight on the MSO, etc. I understand that curb weight and shipping weight are different. Is there a reliable resource that lists shipping weights of each option? At GM heritage information, there are conflicting shipping weights and curb weights. Plus a big block radio weighs 14 lbs, while a small block radio weighs 11? I'm sure the guys recreating documents have them. I'd just like to figure out how GM arrived at the shipping weight on the MSO for my 71. The documented options and weight don't dovetail.
  • Ron G.
    • December 1, 1984
    • 866
    Re: Vehicle weights
    Mike, Would you mind posting a photo of your 71 and 72 certification labels? Thanks. - Ron
    "SOLID LIFTERS MATTER"
    • Mark H.
      • September 18, 2013
      • 241
      Re: Vehicle weights
      Just a guess here, but there were two different radio options then, U69 which was AM/FM radio and U79 which was AM/FM stereo, which would probably account for the weight difference in radios. Don't think it had anything to do with which engine was used, someone may have just made a mistake when putting those documents together.
      • Mike E.
        • February 28, 1975
        • 5141
        Re: Vehicle weights
        Ron,
        I would prefer not to. I can tell you that the MSO says the shipping weight of the 71 convertible is 3285. I'll check the 72 cert label when it quits raining.
        • Mike E.
          • February 28, 1975
          • 5141
          Re: Vehicle weights
          Mark,
          i was aware that there were two radios. My point is that I'm looking for reliable information. I'm not seeing that as reliable. The shipping weight on the MSO is different than any permutation from GM documents I have seen. Thanks for your reply.
          • John L.
            • February 20, 2009
            • 186
            Re: Vehicle weights
            Mike
            How close are the total shipping weights? Don't look for perfection in this number. Often only the models base shipping wt was provided by manufactures without any options added. Or they were revised during the model year after a "weight audit". There primary purpose was for state license registration. Also identical equipped individual vehicles varied by up to +/- 10 lbs or more.
            • Patrick B.
              • August 31, 1985
              • 2012
              Re: Vehicle weights
              My copy of the MVMA specs for 1972 Corvettes lists the curb weight of the convertible as 3306 lb and the LS-5 as an additional 222 lb. This seems to me as pretty reasonable. I once weighed my 70 LT-1 coupe on a truck scale and it was 3301 lb.
              • Mike E.
                • February 28, 1975
                • 5141
                Re: Vehicle weights
                John,
                Explain further, if you will, how identically-equipped cars would vary +-10 lbs.
                The calculated shipping weight of the car with MSO statement of 3285 is 3392.
                • Mike E.
                  • February 28, 1975
                  • 5141
                  Re: Vehicle weights
                  Ron,
                  Here is the 72.
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11363
                    Re: Vehicle weights
                    Mike, Sorry I can't add any value regarding the specific data you're looking for, but one note about the possible radio weight differences.
                    Based on which type and when used on Big or Small block, I seem to recall total Radio Option weight includes ALL Radio Supression parts. This includes all of the Ignition Shielding, Ground Straps, antenna ground planes, amplifier(if applicable), etc. There must be quite a difference in total weight of all of the various configurations of radios based on option type and engine size.
                    Rich
                    • John L.
                      • February 20, 2009
                      • 186
                      Re: Vehicle weights
                      Mike
                      I would use the shipping weights and option wts in the AMA documents even though they may have been revised or updated during the model year. The MSO wt may have included options and a few gallons of fuel,...shipping wt should not include any fuel and I seriously doubt the plant weighed very many vehicles but I am sure they probably had vehicle scales. How a weight would be included on your FMVSS label??, but it would have to be computer generated same as the date and VIN.
                      The simple answer to your question about production weights is production variance. Each of the thousands of parts in a vehicle have variability and therefor the vehicle. Without boring you with the minutia, during my 40 years in the auto industry I've had to actually go to plants to weigh vehicles (and parts), plot a distribution to determine a mean and report a number.
                        • 15706
                        Re: Vehicle weights
                        Shipping weight is with all normal vehicle equipment including spare tire,jack and tools, full fluids except gasoline which is 3 gallons. Gasoline weights about six pounds per gallon. Curb weight is as above except with full fuel. The weight label in the door jam is GVW, which would add about 400-500 pounds to curb weight.
                        • John L.
                          • February 20, 2009
                          • 186
                          Re: Vehicle weights
                          Duke/Mike
                          I think Mike is saying there's weight numbers on his FMVSS cert label. In this time period I think the Gross Axle Ratings (GAWRf/GAWRr) and the Gross Vehicle Weight Rating (GVWR) and maximum load capacity and tire pressure,.. were on the Tire/Load label Later all this information was combined into one label.
                          Question: Is The weight of the 3 gallons of fuel in the shipping weight??
                          Answer: Manufactures might have been but usually were not including the wt of any fuel,...
                          Question: Why not?
                          Answer: (1) Because this evolved into a number used by states for titles and taxes and the owner/operator already is paying state and federal taxes on the fuel and wouldn't want to pay again every year. (2)And this number was only one of several used for shipping. (3) And the added fuel at a manufactures plant could be a lot more than 3 gal,......I saw one example were the fuel fill was 15 gal for a 20 gal tank and the plant was having a hard time doing it (why??,..something to do with money as always)
                          (Im not feeling well today and have nothing better to do than answer my own questions)
                          • Mike E.
                            • February 28, 1975
                            • 5141
                            Re: Vehicle weights
                            Actually, I am referring to the manufacturer's statement of origin. This is a 71, so there is no weight data on the blue certification label.
                            GM documentation says the shipping weight includes 3 gallons of fuel. John, thanks for sharing your experience.
                            • Mike E.
                              • February 28, 1975
                              • 5141
                              Re: Vehicle weights
                              Rich, that is a good thought. Big block only had braided cables and distributor cover. Small blocks also had vertical shields and lower horizontal shields with brackets for them. Could be the 3-pound difference.
