What position are the window cranks supposed to be either when the windows are up or down. 1971 Roadster.
Also with the soft top is there any mounting hardware holding the top to the bottom rear bow. When I took mine apart it appears only the weatherstrip with the pull cord holds the top on. I noticed thought that there are some screw holes on the bottom side of the bow, not sure what they were for??
Sheldon
Sheldon
