1967 Brake Caliper Cotter Pin Location? - NCRS Discussion Boards
  • Rick G.
    • March 1, 1983
    • 275
    Can someone please tell me the correct factory location, inboard or outboard, of the cotter pin which is in the rod that goes thru the brake pads on a 1967?
    Thank you,
    Rick
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 1967 Brake Caliper Cotter Pin Location?
    Inboard.....
    • Bill W.
      • November 1, 1977
      • 402
      Stephen is correct, the reason being that if the cotter pin ever fails the pin will be retained by the wheel. Bill
      • Rick G.
        • March 1, 1983
        • 275
        Stephen & Bill,
        Thank you. The reason I bring this up is I recently purchased four rebuilt calipers from one of the major rebuilders and they all were outboard. Bill's reason makes sense to me.
        Thanks again,
        Rick
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11362
          Also if the ends of the pin are outboard and bent and cut too long, they can hit the wheel, particularly KO's.
          Rich
