Water pump 1993 - NCRS Discussion Boards
Water pump 1993
  • Frank K.
    • January 1, 2000
    • 319
    Water pump 1993
    Should the water pump shaft be free to spin when new off the car?
    • 43259
    Re: Water pump 1993
    Frank-------
    The waterpump drive shaft should be free to turn. However, I don't think it's going to "spin" due to the drag of the seal. It might be a bit hard to turn because the short, splined shaft is so small.
    • Frank K.
      • January 1, 2000
      • 319
      Re: Water pump 1993
      Your correct! It turned only with vise grips. Thanks again.
