Clutch Control Shaft Finish? - NCRS Discussion Boards
  • Peter S.
    • March 28, 2012
    • 327
    What is the appropriate finish for the clutch cross shaft? 1969 350 ci M20 if it matters.
    • 43247
    Re: Clutch Control Shaft Finish?
    Peter------
    Zinc plated although some might have been electro-galavnized. Either finish appears about the same.
    If you intend to have yours re-plated, be advised that the plater MUST use procedures to avoid hydrogen embrittlement.
    • Peter S.
      • March 28, 2012
      • 327
      Thanks Joe!
      • John D.
        • December 1, 1979
        • 5507
        Peter, The plater must bake the part to avoid what Joe called Hydrogen embrittlement. When I get FI parts plated such as split lock washers and little springs I always request the baking. I was told it had to be done within 20 minutes of the part being dipped for plating but I may be wrong on that detail. John
