Judging Scoring Question, Section 2 Mechanical, Cylindar Case Date issue! - NCRS Discussion Boards
  • Anthony S.
    • April 30, 1998
    • 156
    In scoring the section 2 on the mechanical set of sheets:
    Suppose that Section A Cast # and case is good.
    But the casting date is NOT readable. It should be.
    How to score this?
    Option 1: Benefit of the doubt = slash,
    or
    Option 2: Deduct of 175 points (don't score sections C and D stamp pad).
    Thoughts?
    Issues?
    Controversies?
    Thanks TONY
  • Michael J.
    • January 27, 2009
    • 7166
    Re: Judging Scoring Question, Section 2 Mechanical, Cylindar Case Date issue!
    That's a tough one if the casting date is illegible. Is there an engine assembly date and suffix stamped on the pad?
    • Guest
      would also be looking at Trim tag for build date of car; other obvious parts with date codes; anything to ascertain approximate casting date; VIN will also provide approximate cast date
        • 15630
        How to score this?
        or
        Thoughts?
        Issues?
        Controversies?
        Thanks TONY
        That is a "consult with the Team Leader" situation Tony.
        • Dan A.
          • May 31, 1974
          • 1073
          If the casting date is illegible do to an accumulation of dirt in oil the scoring would not be in the owners favor. The manual states that the owner has a responsibility to make sure the pad and the cast number and date are clean as they would have been when the car rolled off the line with dealer prep..
          If the casting date is illegible due to "stickers" as the late Mark Gorney a long time GM Central Foundry in Saginaw employee has explained in the past occurred and other dates and configurations line up then the owner would likely benefit for the "benefit of the doubt".
          "Sticker" occurred when sand fell out in the date and casting number area thus giving an obscured casting.
            • 15630
            Good points Dan, you are correct, but I still hold that it is time for the judges to consult with the Team Leader. I would expect the Team Leader to apply the logic you have stated as well as looking at the stamp pad to try to decide if the cylinder case could be original or a "convenient replacement."
            • Guest
              Terry - meant to add TL consultation but totally forgot and you posted before I could "correct" my post
              • Arland D.
                Moderator
                • July 31, 1980
                • 428
                All good points and it may not end with the team leader. One such casting date issue arose at a regional with the judges and (a former) team leader not in agreement as to a final disposition. The national judging chairman was asked for input to resolve the stalemate. The detailed results were written on the judging sheet and the owner was advised to carry the judging sheet to future meets for clarification if any questions came up. Our judging system works very well when all the procedures are used on the judging field.
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11362
                  Okay, So how would my wife's '63 Coupe do?
                  v
                  v
                  I saw it as " B 12 3" before I bought the car.
                  v
                  v
                  Here's the stamp pad....
                  • Michael J.
                    • January 27, 2009
                    • 7166
                    Pad looks bulletproof, forget the casting date........
                    • Joe R.
                      • July 31, 1976
                      • 4552
                      Anybody gonna comment on the 63 SN tag being attached with Rosette Rivets. Should it not be spot welded?
                      Just an observation!
                      JR
                      • Jim D.
                        • 2885
                        JR
                        What tag are you looking at? The one RM posted is perfectly fine.
                        • Paul D.
                          • September 30, 1996
                          • 491
                          Richard, I just want to hear the back story on that yellow paint! Chip.
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11362
                            Hey JR.....YOU WANNA BORROW MY EYEGLASSES! 😄
                            • Richard M.
                              Super Moderator
                              • August 31, 1988
                              • 11362
                              Chip, I asked that question here many years ago. The engine had yellow paint under the original Orange when I got it in Dec 2007. 67k original title documented miles.
                              In Jan 08, wifey drove it to Kissimmee for the Regional to get it looked at for Bowtie eval. I'll check the sheets to see comments on cast date as well as the yellow, I forget what transpired.
