Harmonic balancer question ? - NCRS Discussion Boards
  • Bob W.
    • December 1, 1977
    • 802
    How can i tell if i need to reboild my balancer? If so is their anyone who can do this here on the east coast.
    Thanks Bob
    • 43219
    Re: Harmonic balancer question ?
    Thanks Bob
    Bob------
    First, check to see if the outer ring has slipped with respect to the hub. For 1955-68 balancers, the keyway in the hub should align with the timing mark on the outer ring. If it's displaced, the balancer definitely needs to be rebuilt or replaced.
    Next, inspect the exposed rubber to see if it's badly cracked. If it is, that might be a clue that the balancer needs to be rebuilt. However, it could still be OK because the outer portion of the elastomer has no functionality and the inner portion, the important part, could be OK. Nevertheless, if it appears deteriorated, it might be time to rebuild or replace.
    I do not know of a rebuilding source on the east coast.
    • Mark E.
      • April 1, 1993
      • 4537
      Also check for axial and radial runout. Watching it at slow idle with a good shop light is a quick visual way to do this.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Bob W.
        • December 1, 1977
        • 802
        Joe/ Mark Thanks for your reply's as always i can count on everyone here for help.
        Bob
