Hooking up new wiring to 63 wiper motor - NCRS Discussion Boards
  • Chester C.
    • May 29, 2013
    • 154
    Besides the pump wiring, there are 3 wires in a terminal that go to the wiper motor. There is a middle wire and then a red one and a yellow one. When connected to the wiper motor does the yellow wire face towards the firewall or the engine. Thanks
  • Chester C.
    • May 29, 2013
    • 154
    Re: Hooking up new wiring to 63 wiper motor
    Now I'm really confuse. I've found posts that say the yellow wire faces the front of the engine. And another one that says just the opposite. Maybe since the middle wire is the hot wire it makes no difference. 63/64 owners, if you have a chance look at your wiper wiring please and let me know, thanks.
    • Bob R.
      • June 30, 2002
      • 1596
      My car is not accessible right now but I just looked at the 63 AIM wiring diagram and the three wires for the wiper motor are in the following order Y = drivers side BRN = center location and R = passengers side.
      • Chester C.
        • May 29, 2013
        • 154
        Thanks for your help but I'm still confused due to the plug being perpendicular to the doors. Maybe with your info along with other clues I can figure it out.
        • Brian T.
          • September 30, 1990
          • 190
          You may want to try installing the plug. There are notches in the plastic to allow it to slip over the small protrusions on the wiper motor terminal board. Should not install the wrong way.
          • Joseph S.
            National Judging Chairman
            • March 1, 1985
            • 934
            Brian is right. Due to the shape of the connector, there is no way to hook it up backwards.
            • Chester C.
              • May 29, 2013
              • 154
              Got it hook up and running, thanks everyone
