1964 Chassis Questions - NCRS Discussion Boards
  • David R.
    • February 1, 1990
    • 71
    I am assembling my chassis and I need help. I have two questions:
    Question #1
    The frame is a Vette Products reproduction. My old frame is gone. I took pictures of most everything, but missed the detail on this hole location. VP doesn't drill holes for fuel or brake line clips.
    The Assembly manual shows a clip in this position, but I'm unsure where to locate the hole. Can someone please help me with a measurement and/or picture?
    Question #2
    I have an original correct idler arm in good condition. The rubber boot seals are not usable. Does anyone know where I can buy correct appearing replacements?
  • Leif A.
    • August 31, 1997
    • 3651
    Re: 1964 Chassis Questions
    No measurements but maybe this picture will help.
    Leif
    • David R.
      • February 1, 1990
      • 71
      Leif,
      Thank you! that picture is very helpful.
      • Alan D.
        • January 1, 2005
        • 2053
        Measurements just done by hand, so not exact! (From original Mar64 frame)
        • Peter M.
          • May 30, 2013
          • 360
          David,
          This is a 67 frame if it makes a difference. The shaded area at the bottom of the tape represents the weld. If you want anything else let me know.
          This is not accurate to the thousandth of an inch.
          Kind regards
          • David R.
            • February 1, 1990
            • 71
            Thanks to All!!
            I also found the idler arms seals at LIC.
            David
