Re: C1 Reproduction Temperature Senders
Rich------
The GM #1513321 was an original temp sender. In addition to its PRODUCTION use, it was once SERVICE for all 56-78 Corvettes. However, the 1513321 was not used for all of 1956-78 PRODUCTION. The 1513321 is a BUTTON terminal sender. 1968-71 Corvettes used a PIN terminal sender. I believe that some early C1 did too. In any event, I believe the 1513321 is calibrated the same as the pin terminal sender.
I don't know why the 1513321 you have did not test out properly. Was the bag SEALED when you got it?
Rich------
