Will follow up later but I am again pulling hairs to get one that is not 30 to 50 degrees apart from the known good gauge comparing by using IR measurements at the sender and intake sender housing. #'s 1, 2, 3, 4 are no good. Some are 20* out, some 30* out and gauge reads higher than actual. #3 is in the engine right now and ~20* high on gauge.
The chart was made measuring resistance with IR gun and my heat gun on the bench. Not perfectly accurate method but trying to see variances to select the best one. I have tried 4 of the 6 I have, and just got a Wells TU-5 at Auto Zone yesterday and trying that one today after some heat gun/ohms test. Will post results later.
What a PITA.
What a PITA.
At 180* water I get 179 ohms.
