Black paint finish on YJ8 wheels - semi gloss, satin, or flat? - NCRS Discussion Boards
  • David C.
    • June 30, 2006
    • 126
    I've acquired a set of first design Kelsey Hayes YJ8 aluminum wheels (#363768) for which I need to repaint the black out center hub area. Existing finish looks to be semi gloss but they have likely been repainted in the past.
    Does anyone know what is the original finish on the black paint -- was it semi gloss, satin, or flat black?
    I don't know if it indicates this in the 1975-77 judging guide (I have the 73-74).
    Thanks much.
  • Jimmy P.
    • June 24, 2014
    • 1695
    Re: Black paint finish on YJ8 wheels - semi gloss, satin, or flat?
    They are semi-gloss.
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
    • Michael W.
      • April 1, 1997
      • 4290
      I bet there's only 2-3 people here who have ever seen an original 363768 wheel (I'm not one of them) and I'm not sure the paint gloss would necessarily be the same as the later wheels.
      • David C.
        • June 30, 2006
        • 126
        These are the 'first design' K-H wheels offered in 1976, not the original 1973 American Racing mags. I had understood these were fairly common.
        • Harmon C.
          • August 31, 1994
          • 3228
          I have a set of five 73 wheels one is NOS.I need the lug nuts as they are smaller with a black center.
          Lyle
          • Michael W.
            • April 1, 1997
            • 4290
            Yes you're right. The term first design and the fact that you've a '73 threw me off. The '73 wheels were 329381.
            • David C.
              • June 30, 2006
              • 126
              Hi Lyle, can you tell me what is the finish on your original wheels' blackout area? Is it flat, satin or semi-gloss? Thanks.
              • Jimmy P.
                • June 24, 2014
                • 1695
                Hi Lyle,
                Is it true that the lug nuts used for the original AR wheels that you are seeking are specific to those wheels and are not interchangeable with the KH wheels?
                Also, would you or anyone else know for sure if what I read somewhere that supposedly three of the four wheels on Zora's '74 in the NCM are indeed from the original four sets?
                Jimmy
                1973 Convertible
                L48,M20,N40
                • Michael W.
                  • April 1, 1997
                  • 4290
                  Jimmy,
                  The lugnuts are not interchangeable.
                  There were hundreds of sets of wheels made, not just four. Almost all were sent back to GM under a recall, some did not. Every now and then an individual wheel or a set pops up. There were two wheels for sale on eBay in Feb.
                  • Harmon C.
                    • August 31, 1994
                    • 3228
                    The lug nuts have black centers and are smaller a 76 lug nut will not fit in the hole on a 73 rim. Zora's car in the NCM has some 73 rims but I never checked them all.my 73 in the body drop is just down the hall.
                    Lyle
                    • David C.
                      • June 30, 2006
                      • 126
                      One more ask for input on my original question -- were these wheels painted black semi-gloss or satin?
                      Thanks.
