Pictures say many words. Another reproduction part bites the dust. This now adds to the prior total of 21 reproduction items on this car, making it defective reproduction item #22. That's right, I'm keeping a count and will be writing emails to ALL of my suppliers so they can fix this. It is getting out of control. This is what made me look up with the car on the lift after some test runs yesterday.....
looks like blood I said. Nope. I looked up and saw a drip on the bottom of the balancer. More pics below.
So I am in dire need (scratch that!.....my friend John Baldwin read this, called me, and just dropped off 3 pumps, one of which that I will blast, rebuild, and paint and be done with this today!
)..of a REAL GM 3782609 water pump(with the proper bypass elbow threads in the boss), so I can rebuild the stinking thing myself so I know it's done right. The last 4 water pumps I have acquired, both bog block and small block, have each had some form of unacceptable issue and I have had to RE-Rebuild them all.
The above repro 609 pump was coming off anyways, as it's making noise, likely the stamped steel impeller is hitting something, so I was going to rebuild myself. Now I just noticed the cast iron itself is junk.
Rich
PS At least I have other reproduction junk like door panel lock knobs and bad voltage regulators and so much more to work on while scouring the planet for a good water pump.
)..of a REAL GM 3782609 water pump(with the proper bypass elbow threads in the boss), so I can rebuild the stinking thing myself so I know it's done right. The last 4 water pumps I have acquired, both bog block and small block, have each had some form of unacceptable issue and I have had to RE-Rebuild them all. The above repro 609 pump was coming off anyways, as it's making noise, likely the stamped steel impeller is hitting something, so I was going to rebuild myself. Now I just noticed the cast iron itself is junk.
Rich
