Engine oil pan question - NCRS Discussion Boards
    • 6955
    Does anyone know if a C-1 oil pan will work on a 64 S/block, no power steering car.( installing a 62 vintage engine). engine is from a Corvette.
    • 43271
    Re: Engine oil pan question
    Edward-----
    A C1 oil pan will work perfectly on a 1964 short block. However, you'll have to also use the C1 oil pick-up tube and screen and you'll have to use a C1 dipstick and tube.
      • 6955
      Joe, As always thanks for the info.
