57 door reinforcement - NCRS Discussion Boards
  • Darryl D.
    • February 7, 2017
    • 386
    My car is too early to have these. are they made repo?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11334
    Re: 57 door reinforcement
    Darryl,
    No reproductions are available as far as I'm aware. You'll likely have to locate used original parts. This will require substantial work to fit them.
    BTW, there are reinforcements under the dash as well and help prevent dash sagging.
    Rich
    • Joe M.
      • February 1, 2005
      • 590
      just had my early 57 door skin off and compared the innards to a 59 or 60 door just to see what i could see. The early door has some fiberglass reinforcement that needs to be chiseled out to fit the metal reinforcement. Certainly doable with patience. the forward window runner is different as well.I can post pics later if needed.Saw no compelling reason to put in the metal reinforcement.
      • Darryl D.
        • February 7, 2017
        • 386
        Does anyone know where I might find them used or a pattern to make
        them?
