427 Push Rod Design - NCRS Discussion Boards
427 Push Rod Design
  • Chris H.
    • April 1, 2000
    • 837
    427 Push Rod Design
    Was considering replacing the original push rods with Crane's OEM replacements. I noticed the tip designs were different. The Chevy pushrods have a "cup" at the end where the Crane's do not.
    I would like to use the Cranes as it's a one piece design, etc, but am concerned that the Crane design is not compatible with the Chevy lifter and rocker.
    Am I being being overly concerned?
  • Joe C.
    • August 31, 1999
    • 4598
    Re: 427 Push Rod Design
    Yes you are.
    The new pushrod has more contact area than the old one which has a pressed in hardened tip.
      • 43257
      Chris------
      Are these 7/16" or 3/8" pushrods?
      • Chris H.
        • April 1, 2000
        • 837
        Joe, 7/16ths. My concern is the Chevy tips seem to have a larger "funnel" than the Crane tips. I'm concerned that not enough oil will get pushed up the Crane rod to the rocker.
        • Jerry M.
          • March 1, 1978
          • 147
          Chris,
          Chevy offered a set of pushrods through their Chevy Power catalog that looked a lot like these when we built my '66 427/425 around ten years ago or so. One piece design without the traditional hardened tips. Four pushrods wound up wearing down and basically started to disintegrate in short order.
          Replaced them with traditional design and no problems since.
          You really don't want this problem.
          Jerry
          • Chris H.
            • April 1, 2000
            • 837
            Joe, I was mistaken, they're 3/8ths.
              • 43257
              Chris------
              Good. The 7/16" pushrods were originally used only for 1969 L-88 and ZL-1. I do not recommend their retrofit to any other big block.
              Both the Crane and GM pushrods you picture are what's called "180 degree" pushrods. That means the tip is designed to operate through a 180 degree arc. This is sufficient for the vast majority of applications. Welded ball type pushrods, used on many later engine applications, are "270 degree" pushrods.
              • Mark E.
                • April 1, 1993
                • 4603
                How to Hotrod Big-block Chevys has a pictorial history of the various factory push rods and PNs. If I was in town I would refer to it and give you a more useful reply.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • Chris H.
                  • April 1, 2000
                  • 837
                  Thanks Mark, I actually have that Book. I'll check it out when I get home tonight.
                  • Mark E.
                    • April 1, 1993
                    • 4603
                    I installed Crane push rods in my LS-5 a couple years ago, and the engine seems happy.
                    Your L71 is a different animal, of course.
                    Mark Edmondson
                    Dallas, Texas
                    Texas Chapter
