1966 L79 - Oil Change Guidance - NCRS Discussion Boards
  • Edmund C.
    • April 14, 2015
    • 232
    Gents: I plan to change my oil tonight in the garage. Can one of you wise hands please advise the following for my 1966 L79:
    1. What is the modern Delco filter number;
    2. What specific oil brand and type do you recommend (I live in Houston - she's hot);
    3. What's the exact capacity of the crank case (I never seem to get it precisely right); and
    4. I like putting in a small amount of Marvel Mystery Oil (are you generally OK with that).
    Any guidance on these sophmoric questions would be most appreciated. Many thanks. Best, Ned
  • Larry M.
    • January 1, 1992
    • 2701
    Re: 1966 L79 - Oil Change Guidance
    Ed:
    1. If you still have the original metal canister filter housing then go to NAPA and buy the NAPA Gold Filter #1143. This is a WIX filter and should still be made in the USA. Not certain you will find an AC DELCO filter anymore............but is was PF-141. The NAPA Gold is far superior to the DELCO at this time.
    2. I would buy Shell Rotella 15W-40 motor oil. Spec CJ-4 or CK-4. CJ-4 is preferred if possible. Buy 6 quarts.
    3. The oil pan on the 1966 L79 holds 4 quarts + 1 quart for the filter. You will add 5 quarts and this should fill her up. The extra quart from above is for topping up over the coming months.....and to serve as a reminder of exactly what oil you added.
    4. You don't need the MMO, but I won't tell you NO.
    Larry
    • Edmund C.
      • April 14, 2015
      • 232
      Larry:
      Thanks man. I do not have the metal cannister filter; so, will the NAPA Gold Filter #1143 still work? Have a great weekend an dthanks again. Best, EWC
      • Leif A.
        • August 31, 1997
        • 3653
        Ned,
        Larry answered your questions precisely with what I do. If you're using a spin-on conversion oil filter, then use the Wix #51060 or #51061 replacement.
        Leif
        • Larry M.
          • January 1, 1992
          • 2701
          Originally posted by Edmund Chapman (41141)
          Larry:
          No the #1143 is for those still running the original metal can. You need to tell me what is on your car at this time for me (or anyone) to get a cross reference and a recommendation. But otherwise just bring it to NAPA with you and get one of their Gold filter to match what you already have.
          Your old filter should have a label or part number painted on the shell.
          Larry
          • Edmund C.
            • April 14, 2015
            • 232
            Hey Lief. Many thanks. Hope that all goes well.
              • 15706
              Originally posted by Larry Mulder (20401)
              Ed: 2. I would buy Shell Rotella 15W-40 motor oil. Spec CJ-4 or CK-4. CJ-4 is preferred if possible. Buy 6 quarts. Larry
              Brand makes no difference... just make sure the API donut has CJ-4 or CK-4 is the FIRST listed service category. Walmart has a good selection including their Super Tech house brand. Just buy the least expensive.
              • Michael W.
                • April 1, 1997
                • 4290
                1. I like putting in a small amount of Marvel Mystery Oil (are you generally OK with that).
                An old friend once said that this is similar to putting a dab of mayonnaise in a tub of axle grease. If mixed well, it won't hurt the taste of the grease at all.
                MMO was a popular thing in '50s but that was a long time ago.
                • Leif A.
                  • August 31, 1997
                  • 3653
                  Ned,
                  Also, fill the new filter with oil and smear some oil on the new gasket (that's already installed on the filter) before spinning in place. Spin the filter on until it bottoms out and then give it another quarter turn...don't over tighten the filter. Additionally, don't over tighten the drain plug...finger tighten and then just "snug" with the wrench.
                  Leif
                    • 15706
                    Originally posted by Leif Anderson (29632)
                    Ned, Spin the filter on until it bottoms out and then give it another quarter turn...don't over tighten the filter. Additionally, don't over tighten the drain plug...finger tighten and then just "snug" with the wrench.
                    Spin-on filters are usually tightened one-half to three-quarter turn from the point that the gasket contacts the seat. Instructions should be on the box sometimes on the filter itself. The torque spec for the oil drain plug is 20-25 lb-ft, but this often over-crushes the OE type nylon gasket resulting in seepage. The solution is to use a modern design gasket with the proper torque spec.
                    • Jim T.
                      • March 1, 1993
                      • 5351
                      Edmund you asked about an AC Delco oil filter. I use the AC Delco PF2232 Duraguard in my 68 L79, 1970, and 1985 Corvettes. Have used this filter for years, it is AC Delco diesel pickup truck filter. I also use diesel oil 15-40 in my Corvettes for engine protection. Always prefill my new oil filters before installing them.
                      • Ed S.
                        • August 6, 2014
                        • 1388
                        Edmund,
                        Get the engine to operating or near operating temp, then shut it down, wait about 20 to 30 minutes, then drain the oil. Be prepared to move your hands out of the way of the still-pretty-warm oil when you unscrew the oil plug & filter. You will get the greatest amount of old oil out of the engine when the engine & oil are good and warm. Enjoy!!
                        Ed
                        • Edmund C.
                          • April 14, 2015
                          • 232
                          Fellows: Many thanks. Worked great.
