Ignition - NCRS Discussion Boards
Ignition
  • James C.
    • July 4, 2012
    • 81
    Ignition
    I am changing the key cylinder on my 64 to a one hole unit.
    When I removed the old unit there was some grease at the end.
    Can someone tell me the best grease to utilize?
    Jim
    • 6941
    Re: Ignition
    Jim, if there was a grease used it maybe something like dielectric grease, and would say not to put more that just a small dab as your dealing with electric contacts in the switch.
    • Harry S.
      • July 31, 2002
      • 5295
      Re: Ignition
      Jim, did you replace the entire cylinder or just the chrome bezel? The old bezel should just pop off and pop on the one hole bezel. Just add a spot of silicone to hold in in place.
      • James C.
        • July 4, 2012
        • 81
        Re: Ignition
        Thanks Ed & Harry, appreciate it.
        Jim
