New API engine oil service categories - NCRS Discussion Boards
    • 15703
    I was at Walmart last week and noticed that some brands have the new CK-4 primary service category and some are still CJ-4. The API and manufacturers state that CK-4 is "fully backwards compatible with prior C-categories." There is also a new FA-4 spec that I will get to shortly. I know many of you are hung up on brand names, but don't just blindly pull something off the shelf because it looks familiar. Verify the the "API donut" on the back carries a primary C-category, which will likely be CK-4 or CJ-4. The FA-4 is for new HD engines that should hit the road this year. They will be available only in xW-30 grades and the emphasis is on lower internal friction for better fuel ecomomy and less CO2. There will also likely be a reduction in "heavy metal" additives, which means less ZDDP. Other anti-wear additive will take their place, but I don't know if they are as effective. New HD engines will have detail internal design changes like bearings and rings to be compatible with FA-4. I have not yet found any detailed FA-4 specs from any manufacturer, so I don't know if they will be suitable for vintage engines with sliding surface valve trains or not, so stick with CK-4 or CJ-4. Next time I buy oil I'll buy the least expensive C-category oil I can find, as I usually do, regardless of whether it's CK-4 or CJ-4. Just make sure you don't buy FA-4 for now.
    • 11659
    Re: New API engine oil service categories
    I have not yet found any detailed FA-4 specs from any manufacturer, so I don't know if they will be suitable for vintage engines with sliding surface valve trains or not, so stick with CK-4 or CJ-4. Just make sure you don't buy FA-4 for now.
    Short answer - no.
    I visited a Shell display at an event last year, and the FA-4 does not have enough ZDDP and is not for vintage engines. The in-depth explanation did give numbers too. I don't recall the number exactly, but 800 comes to mind. It is made for new design diesel motors only.
    Patrick
    • Ray G.
      • May 31, 1986
      • 1189
      Thank You Duke
      I hope you dance
      • Francis F.
        • April 1, 1978
        • 420
        Duke, thanks for the up-date....Francis
        • Stuart F.
          • August 31, 1996
          • 4676
          Guess I best check the latest jugs I bought "blindly" off the shelf. I did notice the design of the container changed, but thought nothing of it at the time. Maybe have to return it soon as I was about to do an oil change this next week. Finally got our medicals under control here in Houston today, so looking forward to get back together in Orlando with my baby.
          Stu Fox
          • John L.
            • February 20, 2009
            • 186
            Gents
            I noticed that Ford is now recommending that Ford Diesel owners not use CK-4 because "company testing of some of those formulations revealed accelerated engine wear on some 6.7 liter engine components.....". I 'm not sure if this isn't just a marketing ploy because their "new spec" CK-4 with WSS-M2C171-F1 spec is ok (or use CJ-4/SN they say, but CJ-4 will be phased out by end of 2017).
            Spring is oil change time and I plan to use CJ-4 but now I am wondering if I should buy some extra CJ-4 rather than move to CK-4 next year??
            What is so different about CK-4??
              • 15703
              I'm still working of figuring out the differences between CK-4 and CJ-4. It involves searching for spec sheets on CK-4 from the manufacturers, which don't seem to be on the Web yet, but anybody can do that. If you have any concerns about CK-4 buy a couple of years supply of CJ-4.
              • Joe R.
                • May 31, 2006
                • 1822
                Hi Duke,
                So once the dust settles will you be updating your fine engine oil article? Hint, hint.
                Joe
                  • 15703
                  There's not much to update since the API and all the major manufacturers say that CK-4 is fully "backwards compatible" with prior C-categories back to CH-4. They also claim greater oxidation resistance and lower wear rates, and it appears than some new anti-wear additives are included to supplement ZDDP. I'm still looking into this and can write a brief "update" when I'm done and send it to Vinny and the chapter newletter editors.
                  • Joe R.
                    • May 31, 2006
                    • 1822
                    Sounds great Duke!!!
                    • John S.
                      • May 4, 2008
                      • 425
                      Duke,
                      I was at Walmart this past weekend. Their house brand is no longer can--4 or KC-4 compatible. Only diesel oils were and one Castro offering.
                      John Seeley
                      67 Black/Teal
                      300 hp 3 speed coupe
                      65 Maroon/Black
                      35k mile Fuelie coupe
                      • Dick W.
                        • 10483
                        Most likely the CJ-4 you saw on the shelf is actually CK-4. Most all the major producers started production of CK-4 by mid year 2016 but API licensing would not let them label it CK until Dec. 1.
                        DO NOT USE FA-4 in vintage engines. It does not have the additive package needed for sliding surfaces such as camshaft and lifters.
                        Dick Whittington
                          • 15703
                          Originally posted by John Seeley (48993)
                          Duke, I was at Walmart this past weekend. Their house brand is no longer can--4 or KC-4 compatible. Only diesel oils were and one Castro offering.
                          Your question comes across kind of garbled, John. On my recent trip to Walmart their Super-Tech house brand still listed CJ-4 as the primary (first listed) service category. Delo was CK-4, and I don't recall for Delvac and Rotella.
                          I didn't buy any, but if I did I would have bought the Super-Tech CJ-4 because it was the least expensive... $9.94/gallon.
