Carter WCFB Carburetor - NCRS Discussion Boards
  • Gerald A.
    • April 30, 1997
    • 45
    Need help identifying a carburator taken off a 1963 Corvette. It is a Carter WCFB, the main body cautioned numbers are 0-1241 and the air horn casting number is 6-1376. There was no I D tag on the carburator. Any help would be appreciated !!!
    Gerald Avery (29089)
    • 43275
    Re: Carter WCFB Carburator
    Gerald------
    All I can tell you is that the numbers you mentioned are not component numbers for any carburetor I know of that was originally used on a Corvette or, even, other Chevrolets.
    • Frank D.
      • December 27, 2007
      • 2703
      Not Corvette, I'd bet my money its a Chrysler carb....they can be made to work on a Corvette with some tweaking...
      Only the base motor 63 used the WCFB carb....that being the 250hp mill...
