Glove box door C2 - NCRS Discussion Boards
Glove box door C2
  • Keith W.
    • June 30, 1998
    • 375
    Glove box door C2
    How easy is it to change a 66 glove box door to a 63 - my 63 door is heavily scratched and marked - is it just the case of removing the corvette logo and putting on the correct one - Keith
  • Keith B.
    • September 15, 2014
    • 1604
    Re: Glove box door C2
    a 64-65 door would be a better choice.
    • Gene M.
      • April 1, 1985
      • 4233
      The drilled hole pattern on 63-65 is total different from the 66-67 script emblem. The 66-67 brush face is total different too.
      • Keith W.
        • June 30, 1998
        • 375
        Thanks for the info Gene / Keith will try and seek a vendor out on e bay ref replacing the door - as always much appreciated and saved me $300 in putting in the wrong door - Keith
        • Keith W.
          • June 30, 1998
          • 375
          • Bob R.
            • June 30, 2002
            • 1596
            I'm not sure I understand what you are trying to do here. The 63 door is fiberglass and the 64 - 67 doors are metal. When I got my 63 it had a 64 - 65 door in it which is common as the original 63 doors crack with age. The 64 - 67 doors should fit in place of the 63 door and as noted above if you want it to look close to correct you should install a 64 - 65 door as they have the same script as the 63. Vendors now sell a reproduction of the 63 door but it is a little expensive.
            • Keith W.
              • June 30, 1998
              • 375
              Bob thanks for the info , my 63 door is heavily scratched and marked just wanted to update to make it look better - I haven't had a close look if its metal of fibreglass - would obviously like to keep it standard - regards Keith
