70-72 expansion tank to radiator hose clamps - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5141
    I know from the new JG that it should be a pair if side-screw clamps on the pressure hose from the expansion tank to the radiator. I assume they are Wittek because everything in that vintage was. My question: what size designation is stamped on it, if there is a size stamping?
  • Rich P.
    • January 12, 2009
    • 1361
    Re: 70-72 expansion tank to radiator hose clamps
    20170413_152610.jpg20170413_152538.jpg20170413_152525.jpg Mike, they were witek side clamps. I know from 1963 through 1969 they were stamped with number 2. It's possible sometime in 70 on up that use the number 23 clamp but I still think it was number two not positive.
    • Mike E.
      • February 28, 1975
      • 5141
      Thanks, Rich. What was the original finish on the strap, as well as on the screw and nut? I have a couple of 2's and 23's, and they look a lot like yours with a charcoal/gray type finish.
      • Rich P.
        • January 12, 2009
        • 1361
        Mike, no problem. If I remember correctly the original clamps were galvanized and the screw and square nut are zinc.
