C-3 Door Handle - NCRS Discussion Boards
C-3 Door Handle
  • Rey S.
    • April 1, 1995
    • 277
    C-3 Door Handle
    Some of my various Vette publications show a gasket under the door handles on C-3 cars, some don't. Is this gasket needed or not. I can't see the need as there is a drain hole at the bottom of the door handle. Rain or car wash water will get into the door it self. So on that basis should I gasket or not
  • Paul O.
    • August 31, 1990
    • 1716
    Re: C-3 Door Handle
    Rey
    The gasket is for paint protection not really for water sealing. So I would use the gasket
    Paul
    • David W.
      • January 19, 2014
      • 112
      Re: C-3 Door Handle
      The factory did not use gaskets.
      • Russ S.
        • April 30, 1982
        • 2163
        Re: C-3 Door Handle
        All c3s had gaskets from the factory.
        • David W.
          • January 19, 2014
          • 112
          Re: C-3 Door Handle
          None of my original C3's have gaskets . Also noted accordingly in TIM&JG. Gaskets are incorrect..........It may depend on specific C3 year.
          • Ed D.
            • December 1, 1990
            • 329
            Re: C-3 Door Handle
            My 72 came with gaskets. There to protect the paint and fiberglass from cracking
            Ed
            Ed DiNapoli
            CNJ Chapter Past Chairman/Co Founder
            1972 Targa Blue Coupe, Original Owner,
            Duntov Award, Sam Foltz Award,
            Founders Award, NCRS Gallery VIII
            2011 Corvette Convertible
            NCRS Presidents Award 2014
              • 43277
              Re: C-3 Door Handle
              Rey-----
              The GM #3956022 seal was definitely used for 1968-69. I have conflicting information if it was used for 1970-76 but I expect it was. From what I can determine, it was not used for 1977-82.
              • Russ S.
                • April 30, 1982
                • 2163
                Re: C-3 Door Handle
                My 73 one owner(until I got it) original paint car has the gaskets.
                Rey-----
                  • 15632
                  Re: C-3 Door Handle
                  Rey-----
                  My 1-owner 1970 has gaskets at the door handles and door locks. For 1968-1972 the Exterior judges look at the configuration of those gaskets as an item they judge.
                  • Paul O.
                    • August 31, 1990
                    • 1716
                    Re: C-3 Door Handle
                    My original 71 also had both gaskets.
                    • Gary B.
                      • July 31, 1979
                      • 926
                      Re: C-3 Door Handle
                      1971 original paint, 24,000 mile car.
                      • Gary R.
                        • April 1, 1989
                        • 1806
                        Re: C-3 Door Handle
                        my early 69 had them as does my 72
                        • Rey S.
                          • April 1, 1995
                          • 277
                          Re: C-3 Door Handle
                          Hi Gary ---
                          Looking at the door handle(s) you have pictured I see the gasket how ever I don't think GM would have used something as ragged as what I see sticking out from the handle edges or are the ragged edges from wear and tear?
                          • Rey S.
                            • April 1, 1995
                            • 277
                            Re: C-3 Door Handle
                            I can see that to agree with Paul O. is why I will use gaskets. I will cut mine to stick out around the edges a smidgen (as Mr. Bosselmans show) so that the handle assemblies contact gasket material rather than paint. If this is not correct so be it, I am more interested in function rather than form.
                            Thanks for all the opinions and help on this matter!
                            • Michael F.
                              • 745
                              Re: C-3 Door Handle
                              I owned 4 70s back in the day (pre 75) all had the gaskets and my current original LT-1 (like Terry's) has the gasket.
                              Michael
                              70 Mulsanne Blue LT-1
                              03 Electron Blue Z06
