2007 Removable see-through top noise - NCRS Discussion Boards
  • Ed S.
    • August 6, 2014
    • 1388
    A friend has a 2007 w/ see-through removable top (black or darkly tinted). Recently it began to make noise while driving - it pops, crackles, & snaps (like Rice Crispies). This just recently started. It is a no hit no damage car. Dealership says, "they all do that when they get older, the top has to breathe". Is this common? Anyone else experience the same?
    Thanks.
    Ed
  • John D.
    • June 30, 1991
    • 875
    Re: 2007 Removable see-through top noise
    Ed
    Not sure about the top having to breathe but there's a bulletin 08-08-67-013H (doc id # 3549757) that details the steps to fix depending on where the noise is. Mostly it involves cleaning the seals and applying dielectric grease and /or minor adjustments to the latches and locators.
      • 11692
      I had my 2008 fixed, and had new latches installed. There is some Velcro-like material (the soft side of Velcro) that they also install as a cushion. That worked for a few years, but last year it started to make noise again.
      You can see if the dealer will try to fix it, else there are other suggestions over on CF.
