Quick question on Oil Changes for "Sleeping Cars"(Corvettes/Camaro's)
Re: Quick question on Oil Changes for "Sleeping Cars"(Corvettes/Camaro's)
I've never understood the perception of these oils being considered inferior to 'car engine' oils. Not much tougher than the duty cycle of a farm tractor under full load for hours or days on end or a commercial truck engine that's expected to last a half million miles without issue.- Top
Also consider that the average size farm tractor nowadays probably costs several hundred thousand dollars, and the big turbo-diesel is likely more costly to manufacture and overhaul than any car engine with the possible exception of some exotic car engines.- Top
Let me rephrase: The "S" specs are for spark engines, and the "C" specs are for compression engines, right? Are there disadvantages/risks with running oil in a spark engine which does not meet any "S" specs? Stated another way, if a "C" spec oil is chosen for a spark engine because of ZDDP levels, is it better to choose one that also meets an "S" spec?
Since separate "S" and "C" specs exist, does this mean spark engines have unique lubrication requirements not provided by compression oils?Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
Like some of the Mobil oils, if you want to buy an S category oil that meets the needs of older cars with regard to zinc, Castrol has formulated one just for us:
Synthetic, and not inexpensive, but if you want to have all 3 (zinc, S, and synthetic) it's one way to go.Vice-Chairman (West), Michigan Chapter NCRS
Ok, maybe "tractor oil" was an unfortunate phrase. Let me rephrase: The "S" specs are for spark engines, and the "C" specs are for compression engines, right? Are there disadvantages/risks with running oil in a spark engine which does not meet any "S" specs? Stated another way, if a "C" spec oil is chosen for a spark engine because of ZDDP levels, is it better to choose one that also meets an "S" spec? Since separate "S" and "C" specs exist, does this mean spark engines have unique lubrication requirements not provided by compression oils?- Top
