1963 stamp pad evaluation - NCRS Discussion Boards
    • 11668
    I have not seen the car in person, just photos. I have my own thoughts regarding this pad.
    Real, not real, or ?
    Patrick
  • John D.
    • December 1, 1979
    • 5507
    Re: 1963 stamp pad evaluation
    Patrick, The car is 1005 numbers or so into March 63. The engine was assembled on Feb 13th. I am just a engine pad novice. Will wait for the guru's to step in. The "R" on the RF looks like the one I typed. I like the R with the fat top to it and the short leg.
    Also have seen a lot of F's that are tilted/slanted. But what do I know.
    • Michael G.
      • November 12, 2008
      • 2157
      Patrick, comparing it to a known original pad of similar vintage, 1) the VIN stamp looks very much lighter than typical, 2) many of the characters of both stamps look correct, 3) as with all pads, the surface is shaped like a "T", but on this one, the base of the "T" is at least 15% wider than the known pad. That suggests to me that some metal was removed from the pad surface...
      Of course, I'm not an expert...
      Mike
      1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
      1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
      • Steve B.
        • March 1, 2002
        • 1191
        Not an expert by any means but I say restamp.
        • Bob R.
          • June 30, 2002
          • 1595
          I disagree, the broach marks are there and you can see age in the surface so I think a re stamp is unlikely.
          • Dan H.
            • July 31, 1977
            • 1369
            The '8' has a wider bottom than the top, see this in later stamps but not on this early type '8'.
            1964 Red FI Coupe, DUNTOV '09
              • 6950
              I agree with Bob the stamp looks good the numbers, letters appear to be correct, broaching looks good. my 63 is a day or two before this stamp and numbers and dates look close to mine.
              • Michael G.
                • November 12, 2008
                • 2157
                Well, the characters look good, but the depth of the stamp doesn't. Maybe the normal guy was on break...
                Mike
                • Michael J.
                  • January 27, 2009
                  • 7145
                  I don't like the R or F in the "RF", and the VIN looks shallow, but I am not an expert.
                  • Jim D.
                    • 2885
                    I agree. I would be VERY surprised if this was proven to be an original,untouched pad. But hey, I've only been looking at pads for 40+ years and still don't consider myself an expert.
                    • Tracy C.
                      • July 31, 2003
                      • 2739
                      Patrick, I'm sure in real life it would pass during a judging event.
                      However comma
                      The downfall for this pad is that with high resolution photos blown up to kingdom come, we see many little nuances otherwise undetectable with the naked eye. Some of the broach marks do not appear to be perfectly parallel. For me this spells re stamp. The fact that the stamp may be is lighter or heavier on one end or the other doesn't bother me at all.
                      It goes without saying, but I will say it anyway. I am no expert and my opinion is worth exactly what you paid to get it.
                      tc
                      • Timothy B.
                        • April 30, 1983
                        • 5196
                        My opinion is it's good to go, the pad probably suffered from paint, scraping, and sandpaper over the years like many of these engines before stamp numbers meant so much.
                        The stamping on my 63 is not deep, I can't see any circular broach marks from previous rebuild but I can't see any straight broach lines either.
                        • Andy C.
                          1963-4 Team Leader
                          • April 1, 1998
                          • 119
                          For Starters the Numeral "1" is not typical of what was used for the serial number stamping. You may want to consult an expert before purchasing the car. Here is a pic of one close to yours
                          Good Luck!
                          • Leif A.
                            • August 31, 1997
                            • 3645
                            Jim,
                            You don't ever want to be considered an "expert". Break the word down...an "ex" is a has been and a "spurt" is a drip under pressure. No one ever wants to be a has been drip. It must be Friday
                            Leif
                            • Rich Y.
                              Infrequent User
                              • April 1, 2012
                              • 24
                              For comparison purposes, I will post a photo of my stamp pad.
                              The assembly dates are only two days apart.
