63-64 Ignition switch - NCRS Discussion Boards
  • Steve S.
    • April 2, 2017
    • 10
    Wondering if this would be a correct replacement ignition switch for a 63 or 64 Corvette? Delco D1434, 1116610. Thanks
  • Harry S.
    • July 31, 2002
    • 5330
    Re: 63-64 Ignition switch
    Steve, correct for a 63 is 1116635. I believe 1116650 is correct for a 64. The 635 is rare and $$$$ the 650 is not as $$$. If you don't need correct I'm sure others will respond.
    • Joseph S.
      National Judging Chairman
      • March 1, 1985
      • 886
      Steve, The 63 cluster housing has the boss for the ign light cast into it. The light screws into the cluster housing. This switch will have an interference issue if you try to install it. You need a switch without the light housing, it will just have a slot for the light beam to shine through. You can find the 635 switches. They run $80 to $100.
      • Joe R.
        • July 31, 1976
        • 4551
        Steve,
        These are a couple pics of the 635 for a 63.
        JR
        • John D.
          • December 1, 1979
          • 5507
          Nice pics Joe Ray.
