63 tail pipe extensions - NCRS Discussion Boards
  • Frank D.
    • December 27, 2007
    • 2703
    Tried to dig this out of the archives but was unsuccessful.
    Was their a recent JG change stating factory tailpipes should NOT have part numbers ?
  • Harry S.
    • July 31, 2002
    • 5308
    Re: 63 tail pipe extensions
    Frank, per the JG Without Part Number
    The extension installed on the line was magnetic stainless steel, no part number and very thin metal, about .0270 thick. The seam at the bottom was either at the 5 or 7 clock position not at the 6 clock position.
    • Frank D.
      • December 27, 2007
      • 2703
      Thanks Harry, I recrafted my search query just now and came up with the same answer via John DeGregory from 2008.
      Too bad, I picked up a gorgeous NOS set still in the GM box for free...oh well!!!
      • John D.
        • December 1, 1979
        • 5507
        Frank, NOS erxtensions are service replacements for 63. Harry. Are you sure about the 5o and 7:00 Position. My original ones are 6:00. Am or PM.
        I was one of the horders that stocked up on exhaust tips or whatever you call them. When my 63 was being restored I found out they weren't worth a crap for a '63. Had to get my bent up ones restored. No part number, very think and 6:00 seam. John D
        • Harry S.
          • July 31, 2002
          • 5308
          John, I know, never say never on a 63. New stuff pops all the time. All I've ever seen is 5 and 7 on the clock. We can always add 6 to the list.
          • Alan D.
            • January 1, 2005
            • 2039
            Have a print for the 3819573 dated 2-24-62 with second rev on 8-30-62. Print calls for seam to be at 30 degrees +/- 1 degree, now the 30 could be to either side and still meet spec since the direction was never spec. Thickness called for is .023 +/- .0025
            • Timothy B.
              • April 30, 1983
              • 5186
              Frank,
              What's the thickness of the service tips you have.
              • Joe R.
                • July 31, 1976
                • 4551
                I have several originals with NO part number and just like John D. says the seam is at 6 without exception.
                JR
                • Frank D.
                  • December 27, 2007
                  • 2703
                  About 0.025 in the spots measured....much thinner than what is on the car now (those are prob repros)...seam is at 6 o'clock and part number on the pieces...
                  • Harry S.
                    • July 31, 2002
                    • 5308
                    Frank, that's why the 63 only rear heat shields are good, covers the numbers when installed.
                    • Frank D.
                      • December 27, 2007
                      • 2703
                      I didn't think about that !
                      They were going on the car anyway - they are clearly better than the thick repros on there now (don't know where they came from)...
                      • John D.
                        • December 1, 1979
                        • 5507
                        JR
                        I agree Joe. I owned two '63's. One from CA and one from PA CA car had 50K on it. My 63 the LWC from PA has about 30K on it. Both cars had the identical exhaust tips. Seam at 6:00. I have know that minor detail for an eon.
                        Jorjorian will tell you that. He will also say you never see a pair of NOS 63's. But tons of the later style. The '63's are very thin and bend easily. JD
                        • Harry S.
                          • July 31, 2002
                          • 5308
                          Here is a set of originals I'm restoring. Close to 6 but not spot on.
                          • Edward J.
                            • September 15, 2008
                            • 6942
                            My 63 tips are clocked about 30 degrees both and I have a set of 64's I will take a look and post them tomorrow.
                            • Stuart F.
                              • August 31, 1996
                              • 4676
                              My original beat up ones are in a box. I'll check them as well for curiosity sake. I recall the tips of the cut off end look like they were kissed by a Mustang or something. He probably couldn't brake with me, Ha!
                              Stu Fox
