C3 Lug Nut Pattern - NCRS Discussion Boards
C3 Lug Nut Pattern
  • Tom R.
    • June 30, 1993
    • 4102
    C3 Lug Nut Pattern
    I need to pick up four rims/tires that will serve as slaves for a rolling chassis but do not care to pay an arm and a leg. I've looked for years at Carlisle and anything with a broadcast code or date code seems to minimum is $50.00 for a rim.
    I figure the local junk yard may be the best shot but then I suspect lug nut patterns have changed over the years for GM and/or Chevrolet. So, what am I looking for to fit a C3?
    Looking up some charts, they show 5x120.7 but is that all Chevrolet from 1968 - 1982? Is the range (datewise) wider? Does it include all GM vehicles during those years?
    I guess the question is...what do I tell the junk man I'm looking for, assuming that's my best option?
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
  • Joel A.
    • September 30, 1997
    • 214
    Re: C3 Lug Nut Pattern
    Tom, iirc, ANY Chev passenger car rim from the 50's to late '70s will have the same bolt pattern to fit...the problem will be to find rims that will clear the brake calipers properly. Some will bolt on and not have any clearance issues, but some may rub slightly, and some will lock down completely. 1/4" spacers usually take care of those. hth
    Joel Adams
    1974 Coupe
    1985 Coupe
    "I know the voices aren't real...but sometimes they have some really kewl ideas...."
    • Keith B.
      • September 15, 2014
      • 1600
      lug pattern is 5 lugs by 4 3/4. Gm still uses this size but in metric on the other site members like mid 90's S-10 spares
      • Jim D.
        • 2885
        Not all of them will clear the calipers.
        • Russ S.
          • April 30, 1982
          • 2163
          IFRC when I picked up mine in apprx.1995 I got rims from a full size chevrolet. I can only guess that they came from apprx. a late 80s to early 90s car.
          • Tom R.
            • June 30, 1993
            • 4102
            So what's the spec that clears the calipers?
            Tom Russo
            78 Pace Car L82 M21
            00 MY/TR/Conv
            • Tom R.
              • June 30, 1993
              • 4102
              What's IFRC...international federation of Red Cross?
              Tom Russo
              78 Pace Car L82 M21
              00 MY/TR/Conv
              • Tom R.
                • June 30, 1993
                • 4102
                So will six inch rims work on a C3 and provide sufficient caliper clearance?
                Tom Russo
                78 Pace Car L82 M21
                00 MY/TR/Conv
                • Gene M.
                  • April 1, 1985
                  • 4233
                  If is from a '67 Corvette it will fit.
                  • Russ S.
                    • April 30, 1982
                    • 2163
                    It's called a typing error.
                    • Paul D.
                      • September 30, 1996
                      • 491
                      Tom, I can't give you specific specs, and certainly have not tried all types of wheels, however I have used 6" and 7" rally rims for "rollers" in the shop. Going out on a limb here, but I think all 15" rally rims may work. I am sure some conventional steel wheels may work (65 and 66 Corvette for sure), but not sure which ones as I have never tried them. Chip.
                      • Tom R.
                        • June 30, 1993
                        • 4102
                        In summary, it sounds like regular steel rims will not work but rally wheels will whether 6" or 8" due to the space for calipers.
                        Thanks Chip!
                        Tom Russo
                        78 Pace Car L82 M21
                        00 MY/TR/Conv
                        • Russ S.
                          • April 30, 1982
                          • 2163
                          Yes regular steel wheels will work. Go back to post #5
                          • John D.
                            • June 30, 1991
                            • 875
                            I know Chev S10/Blazer rims up to 2005 will fit. Some folks run the mini spare in their rear tire well.
                            • Jim D.
                              • 2885
                              I took the mini spare out of a 96 S-10 that was at a friends wrecking yard. It would not clear the calipers on my 65.
