Correct deep groove pulley belt - NCRS Discussion Boards
  • Darryl D.
    • February 7, 2017
    • 386
    Can someone tell me the correct width or better yet the correct belt part # for a 1957 283/270h.p.?
  • Mike M.
    • May 31, 1974
    • 8399
    Re: Correct deep groove pulley belt
    they are available from Quanta, the gas tank folks who ad in the driveline
    • Darryl D.
      • February 7, 2017
      • 386
      OK, but that does not answer my question.
      • Dennis C.
        • June 30, 2002
        • 884
        You can go to Quanta's website and check.
        • Darryl D.
          • February 7, 2017
          • 386
          They don't give the size
            • 43246
            Darryl------
            According to GM it was GM #3738437. It was 3/8" in width and 54-1/8" in length.
            • David B.
              • March 1, 1980
              • 689
              In 1957 Belt #3738437 was listed as 7/16" in width X 54-1/8" in length NO NOTCH TO be used w Deep Ride Pulley
              • Darryl D.
                • February 7, 2017
                • 386
                Well, here we go, two different answers. So which is correct?
                  • 43246
                  Darryl------
                  The 1957 edition of the Chevrolet P&A Catalog shows the GM #3738437 belt to be 54-1/8" long but shows no belt width.
                  1958 and 1959 editions of the Chevrolet P&A Catalog shows the GM #3738437 belt to be 54-1/8" and of 3/8" width.
                  Is this GM-sourced information correct? I don't know; I've never measured one of these belts.
                  • David B.
                    • March 1, 1980
                    • 689
                    The 1957 Dealer Master parts catalog revised November 1, 1957 page 172 does indeed list belt part # 3738437 as 7/16 X 54 1/8 no notch along with notation "For use w/deep ride pulleys"
                      • 43246
                      David------
                      A P&A Catalog dated 11/1/57 would be a 1958 and prior year catalog. My 1958, 1959, 1960, 1961, 1962, 1963, and 1964 P&A Catalogs all say the 3738437 belt is 3/8" wide. The GM #3738437 belt was discontinued in January, 1965 and replaced by GM #3845486. That belt is also shown as 54-1/8" in length and 3/8" wide.
                      As a matter of fact, hundred of belts are shown in each of the above referenced catalogs and, while there are many belts of widths other than 3/8", I can't find a single one that is shown as being 7/16" wide.
                      In general, GM started replacing most 3/8" wide belts in 1973 with 7/16" wide belts.
                      • David B.
                        • March 1, 1980
                        • 689
                        Joe,
                        As you are aware Dealer Master Parts Catalogs were constantly up dated throughout the year to keep current. As mentioned this particular page (172) which was revised Nov. 1, 1957 in Grp. 1.066 is almost entirely devoted to listing all the belts available through 1957. This would coincide with many of the constant changes and up dates for other options such as RPO 579E etc which came out during this year.. Have always found using the correct year parts catalog for the part interested in is more accurate then looking for that part in a latter catalog. If I was more computer smart I would scan and attached page 172.
                          • 43246
                          Joe,
                          David------
                          Yes, there were usually several editions of the P&A Catalogs issued through-out a model year. However, if your catalog was issued 11/1/57, that would normally be a catalog for 1929 through 1958. In any event, my 1957 catalog of unknown date (the cover page and several subsequent pages are missing) shows the 3738437 belt as being 54-1/8" but there is no information as to width. Curiously, the information for this belt is on page 172 of the catalog I have.
                          By the way, sometimes if there is incorrect information shown in a certain editions of the catalogs, it will be corrected in later editions. Not always but sometimes.
                          • David B.
                            • March 1, 1980
                            • 689
                            Joe:
                            I referenced a page up date as November 1, 1957 NOT a catalog issue date. As you know Dealer parts catalogs are loose leaf with pages constantly up dated during the year unlike bound parts books that can not be changed.
                            2 belt sizes were used in 1957 on the Corvette:
                            3712558 3/8 X 54 3/8 Lo HP
                            3738437 7/16 X 54 1/8 Hi HP
                            '57 JM also indicates 2 versions used which is correct HOWEVER, I would question the 1/2 wide (3738437) size or the application on a 56 as it states as being entirely correct. As you mentioned almost all Parts Manuals in later years list 37338437 as being 3/8 X 54 1/8. To offer a possible explanation why the difference I would be inclined to take a look at the 3738437 blue print (I do not have). It might show a revision made from (7/16 or 1/2) to a more generic 3/8 width, the length 54 1/8 and part number would remain the same. In point of time (1957) I believe 3738437 was in fact wider (7/16) as listed in the '57 Dealer Parts Catalog I use. I do not believe this size was a misprint. I cannot explain the 1/2" version or where it came from as stated in the 57 JM.
                            • Darryl D.
                              • February 7, 2017
                              • 386
                              So, where can you buy the 7/16 or 1/2 belt?
